Lesson 1: What is Open WebUI?
With the growing concerns about data privacy in AI tools, many users and organizations are looking for alternatives to ChatGPT.
In this lesson, we introduce you to Open WebUI, a powerful, private, and free alternative that puts you in control of your AI interactions.
What is Open WebUI?
Open WebUI is an open-source ChatGPT style interface that allows you to:
  • Run AI models locally on your computer
  • Work completely offline
  • Access multiple AI models from different providers
  • Maintain full privacy of your conversations
Why Switch from ChatGPT?
  1. Privacy Concerns
    • ChatGPT stores and uses conversation data for training
    • Major companies like Samsung have banned ChatGPT use
    • Open WebUI keeps your data completely private
  2. Offline Access
    • No internet dependency after initial model download
    • Reliable access even without connectivity
    • Perfect for secure environments
  3. Flexibility
    • Choose from multiple AI models
    • Compare different model outputs
    • Use the best model for each specific task
  4. Ownership
  • Stop using Big Tech’s AI systems like ChatGPT, and start using your own instead
Key Benefits of Open WebUI
  1. Complete Privacy
    • Runs entirely on your local machine
    • No data sharing with external servers
    • Perfect for sensitive information and code
    • Works offline once models are downloaded
  2. Model Flexibility
(You can even access proprietary models like OpenAI’s GPT 4o via API should you wish too).
  1. Cost-Effective
    • Free to use
    • Download and use open-source models at no cost
    • Optional integration with ChatGPT API if desired
Features That Stand Out
Prompt Management
  • Built-in prompt library
  • Save and reuse frequently used prompts
  • Quick access using forward slash (/) commands
Real-time Code Preview
  • See immediate results of generated code
  • Perfect for web development tasks
  • Supports HTML, CSS, and JavaScript
Model Comparison
  • Run the same prompt across different models
  • Compare outputs side-by-side
  • Evaluate model performance in real-time
Community Support
Learn how to install Open WebUI on your computer, in our next lesson.
