Working on One Click Install for Open WebUI
Hi Folks,
For the last few weeks @DJJones has been working on an installer for Open WebUI that makes it easy for anyone to download and getting up and running.
We’ll be releasing the first version of the installer for Windows next week. And then working on installers for both Mac and Linux.
Here’s why we’re doing this:
If we want to win the war for our digital brains, we need an alternative to corporate owned AI systems like ChatGPT that gives us ownership and control.
We believe that Open WebUI can be that alternative.
But currently it is too time consuming and too many steps for the average person to get up and running.
That is why for the last few weeks we have been working on a download for Open WebUI that anyone can use to quickly get up and running.
We’re going to start with an installer that requires users to have free docker installed as well too see how people like it.
We will also have an install for more technical users using conda.
@DJJones and I had a conversation about this this morning and here are the highlights for anyone who is interested:
Docker Installation Benefits
  1. Standardization & Reliability
  • Docker creates a standardized environment that works consistently across all machines
  • The application runs exactly as intended by the developers
  • Minimizes conflicts with existing software on your system
  1. System Safety
  • Docker containers are isolated from your main system
  • Installation won’t interfere with other applications or dependencies
  • Easy to remove without leaving traces on your system
  1. Simplicity
  • Once Docker is installed, deploying Open WebUI is straightforward
  • No need to manage complex dependencies or version conflicts
  • Updates are easier to handle
The Only Docker Downside
  • Users need to create a free Docker account if they don’t already have one
  • This is a one-time setup requirement
Alternative: Conda Installation
While we’ve developed a Conda-based installation method, we’re keeping it as an advanced option for specific use cases. Here’s why:
  1. Complexity
  • Requires more technical knowledge to set up correctly
  • More prone to conflicts with existing Python environments
  • Takes longer to troubleshoot when issues arise
  1. Support Challenges
  • Different system configurations can lead to varied installation experiences
  • More difficult to provide consistent support across different setups
  • Requires more user intervention during the installation process
Looking Forward
We’re focusing on making the Docker installation as user-friendly as possible, with plans to:
  • Create a streamlined installation process
  • Improve data accessibility through mounted directories
  • Ensure users have easy access to their files and configurations
  • Provide clear documentation and support
For advanced users who specifically need the Conda installation method, we’ll make it available upon request. However, we strongly recommend the Docker installation for most users as it provides the most reliable and consistent experience.
